G8 to Camaro Rear Sus. Interchange
Wanting to know if Camaro rear suspension pieces interchange with G8? Rear knuckle, toe rod, trailing arm and lower control arm. Camaro parts are fraction of the cost of G8 parts.
If they are GM parts you will have to compare part numbers to be sure. If you go to Pace Performance there is a rep named Greg that can find that stuff out for you. I would also go to one of the G8 specific boards and ask.
I am not sure swapping to Camaro parts will get you any improvements though.
The upper control arm and knuckle are different but will bolt into the G8. The ABS connector is different but they will work. The toe rod and LCA are the same parts. If you swap in the Camaro knuckle/upper arm you can use stock Camaro axles but they are just a smidge too short so you'd need to do something there.
Andy
Andy
