new to G8 L76
new to G8 L76
It's something to hold me over till I get a 8 second car.
Is the pistons, rods, crank the exact spec as the ls2?
Accessories offset the same as 5th gen camaro/ trucks
What the offset range for rims to fit on the car?
Who make that spare trunk sub box and whats the cost?
Can u replace the stock amp with a aftermarket 1?
What's needed to install aftermarket amp?
not sure anyone makes a box, but any reputable shop can, yes you can replace the amp, the stock speakers are usually wired wrong, switch them, and the amp can be adjusted, the stock headunit is a bitch to replace, and there are only a few options available and they aren't cheap, offset depends on many things...
my advice is to get on one of the g8 forums and start reading.
