***NEED HELP***Lingenfelter Launch Control
I need some help. I bought the LNC-003 Launch controller with MPH converter switch. I installed it as per the directions, went over it many, many times and all is right. Everything works but the problem is when i press in the clutch it disables the primary limiter instead of enabling it. It is hooked up as a manual with an arming switch. Any help would be appreciated... Thanks
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
As for the launch controller it works great. There are two clutch switches and the one you use is up high on the GTO's. A small part in the instructions that were left out. Got the info from the engineer that designed it for Lingenfelter.
