Rear end gears for a goat! Help please!
Yep, all the gears are on national back order but should be shipping towards the end of the month.
As far as the strength of the GTO diff. It's plenty strong.
I make the largest stubs on the market for the GTO, huge 33 spline made of 300m. We also make a 33 spline spool and offer a modified Eaton truetrac posi.
There are a couple sponsors on here that you can buy these products through, SNL Performance being one of them.
here is something thay say the are making a 4.10 for the stock gto rear end http://www.ls1gto.com/forums/showthr...21#post5850221
I would hit up vengance they got a nice one peice driveshaft. Also with gears if this is gonna be a steet car and a track car iwouldnt get to extreme with the gears i wouldnt go anymore than the 3.73. Also if you want alot of help hit
Ls1gto.com.
Ls1gto.com.
Hendrix Engineering has a great 8.8 conversion and Vengeance can do the swap.
bring it in the morning and pick it up in the afternoon.
You can buy almost any gear ratio you can think of at about $160 +-
4.10's are available
Actually 4.10's are available through Difftech in Au. and currently more available than the 3.91's because they are after market manufacture. My question is you sure you want to go that low in ratio. With the 3.91's my 65 mph cruising rpm went up to 3500 and don't worry about the strength they are plenty strong. Gforce has run low 9's with this setup, I have gone low 10's with a totally stock rear, and I mean out of a junk yard stock when I pulled the 3.91's out..
i am running a 9" rear and my speedo is not resest yet but it is 15mph off when going 60mph. so what ever a stock 6 speed is turning @ 80 is about what i would be doing @65 right around 2200rpm.
#32
Owner
'04-'06 PONTIAC GTO AXLE UPGRADE 4.11 GEARS + TRUETRAC + MASTER KIT + AXLE SEALS (Fits: 2006 Pontiac GTO)
Brand New
$999.99
I FOUND THIS KIT THAT IS SUPPOSED TO BOLT IN, I AM THINKING OF INSTALLING THEM IN M0 O6.
#34
I installed this kit in my 06 6sp with 515rwhp and a srage 4 clutch they work amazing i do have 30yrs tech experience but if you are going to go from stock ratio to 4:10 gears its going to have to be disassembled any way. I realise the difficulty but if you want to play you either have to pay or learn. If someone has some mechanical ability and patience and can read they can accomplish setting up a differential (with proper tools and equipment) not minimizing the difficulty just saying its possible. So i was just saying these kits are available.
#35
They make a 4.11 gear here down under for the goats. We all run them and they're fine. Link below is a reputable shop I use. Gears that match the goat are referred to as M80 Holden/HSV Commodore
https://www.ebay.com.au/itm/VT-VX-VY...frcectupt=true
