First time on Drag Radials
Scored a good deal on sum MT ET Streets... 275/40/17's
Will have them mounted in the next few days for the track friday.
This will be my first time on Drag Radials. Please advise.
Any tips or stategy would be greatly appreciated.![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
i.e.
tire pressure
drag back psi
launch rpms
etc.
i.e.
tire pressure
drag back psi
launch rpms
etc.
In your Sig pic, were is your induction tubing routed too... Just wondering, As for the DR's.... Drop the PSI to around 20, and launch at about 3000k, I wouldnt really suggest anymore do to breaking driveline parts....
My induction tube run into the top of my FMIC. My goal is 11's. Would i need to leave harder than that to run 11's ?
I run 20-25psi in the bags, and about 16psi in the DR's. On a good day, I could launch around 4500 and stick it. Start around 20psi in the DR's and work your way down by 2psi until they hook for you, but don't go below 15psi.
I wasnt kidding about the 5k launch. You have built driveline, you wont hurt it. It's not easy to get our heavy turbo cars out of the hole with a 2-step, you need lots of RPM out of the hole.
ummm that’s what happened. My tuner was shooting for 7psi and it hit 9 instead. He said he was @ just under 4k and I was already at just over 600whp, so he let out. I asked why it shot to 9lbs when 7lbs was target. He said we were reaching optimum efficiency range of the turbos. IDK I was in the back filming. Perhaps he meant I was on my way to that ballpark figure. Either way it was more than i wanted to make on the stock block "safely". The pull is on YouTube. Those were dyno jet numbers. My new numbers are street tune/mustang dyno (668/682)
5k launch lol. At least the diff...
Yeah I was dumping at abour 4k first time on DR's. Stock clutch didn't like that too much but I was dead hooking and bogging like crazy out of the hole. I wanted to do 5k but I still had to drive home. New 3.5 Monster clutch is on the way, and I moved within 10 mi of the dragstrip so we'll see what breaks first on a 5K dump.
Edit: So you are trying to say this was only 3800rpms,
http://www.youtube.com/watch?v=kAx06Ibzt9M
But this was redline?
http://www.youtube.com/watch?v=6Uj0gYJYITY
I dunno man it all seems pretty shaky to me. Lets see some dyno sheets proving your claims.
The more I look into all the info you say things are not making sense at all. So at 7psi you made 523rwhp on a dynojet, but on 10psi you make 688rwhp on a mustang dyno? So about 750rwhp on a dynojet?
So what you will have me believe is you gained 230rwhp by going up 3psi? I dont care even if the switch from the stock motor to the built one was in there, it doesnt matter. What you are claiming is total BS. Sorry to put you out there like this but man you are making crazy stuff up.
I have been doing this turbo gto thing for a minute, have been through multiple setups. I know what these cars can and cant do, and what you are claiming files under cant do.
Just like in this video:
http://www.youtube.com/watch?v=omKSg-hWwO0
So you will have me believe that your 523rwhp 3800lbs turbo GTO not only yanked out of the hole but proceeded to put more lengths on a 585rwhp 3200lbs Procharged Fox? So a 600lbs lighter car, that makes 62rwhp more than you and you raped him? Come on man.
I can't argue your horsepower claims, I just haven't been in the game long enough to know that possibilities of lsx motors. All I want to know is how I can get 60+ mpg at 101 mph, once I can do that I will believe all your hp claims.
