Pontiac GTO 2004-2006 The Modern Goat
anyone with a hendrix clutch kit ?
Old 09-19-2009, 05:16 PM
maxspeed96ct's Avatar
Default anyone with a hendrix clutch kit ?
Hey if you have a hendrix clutch kit.
What slave cylinder are you running?
Stock ls1 slave or ls2 slave work ok ?
Old 09-19-2009, 05:17 PM
my first GTO's Avatar
We have install alot of Thomas's Clutch's with NO problems and use the f-body slaves.....Frank
Old 09-19-2009, 07:51 PM
K so from what I understand the f-body salve and ls1, ls2 GTo slave is the same in size correct?
Im installing a hendrix clutch on my CTS-V and from the info ive gatherd I should be able to run a F-body slave and just switch my connection lines.
Old 09-19-2009, 09:18 PM
Yes you can....Frank
Old 09-20-2009, 11:48 PM
bravoboost's Avatar
Hendrix clutches are the **** ! BTW ....Made about 750 crank without showing any signs of weakness from the clutch
Quick Reply: anyone with a hendrix clutch kit ?
