what should i run in 1/4 mile????
ok i have an 04 gto with an ls1 and ls6 intake on it..it also has longtube headers with out cats goin straight into slp loudmouth...it has a k/n cold air..and a daiblo sport tune...is a automatic though... but what do u guys think this should run?
I went to the track last year with just Pacesetter Longtubes, O/R Mids, SLP LM1 CB, K&N CAI, Dyno Tune.... I ran a 12.9 @ 108 with a 2.1 60' on street tires.... But im a M6.... You have an A4 which has less power plus you have just a diablo tune which isint getting all the potential of your mods, So i would say maybe a 13.3 or so. But who knows it might be lower with a good 60'. Just my .02
im draggin at la rue in ohio...the track is not the best..very little traction...and i have 255 45 17s on the back..they are just my street tires..so i was thinkin i could prolly run high 13s..like 13.8 or 13.9...ad i was wonderin if any of u guys have 275s on the back of ur gto?bc i put some on and they rubbed really bad with more then 2 ppl in my car
dont get down on yourself
i have basically the same mods execpt mine was tuned with hp turners street tune and i barely had him do anything...take the torgue management out put some timing in it anf firm up the tranny...my car has pulled 13.19 at 107.42 best et...it has ran 107.92...hers my number 3309339001...your from ohio right? i go to 42 all the time...port and polish tb...we should meet up and ill take a look at your car...
when mine was stock and i mean stocktune and all. the best i put down on street tires was a 13.8. but that was only once, but on average i ran a constant 14.0 and 14.1. now with my mods i cannot get enough traction to keep the tires from spinning even with the dr's...
by having my stock 17s widened an inch to 9" it not only provided a much better width for a wider tire but it also pulled the tire in more towards the center of the car away from the fender. i also replaced both rear inner and outer control arm bushing with poly to firm up any lateral squiggle. then by mildly rolling the fenders and putting on 5mm wheel spacers i was able to get 285/40/17 Firestone Wide Ovals (just slightly wider than BFG 275s) back there and can bottom out my springs without any rubbing.
