Hendrix-Engineering 8.8 gb
Hey guys most of you know we develoed the bolt in 8.8 kitt for the gto.The fastest gtos currently use this system and have had great results.We are looking for group buy intrest as it is time to make another batch,please contact me if your intrested and we will see how cheap we can get this gb down to!There are a few options such as 1 or 2 piece drive shaft as well as 800 or 1000 hp axles.The kitt contains everything needed to transfer your GTO into a solid platform that will take all you give it, axles,stubs,driveshaft,rearcover,mounts,and all bolts.100% complete bolt in.All you have to supply is diff,posi and the $130 gear of your choice.Thanks 980-521-0722
Last edited by Hendrix-Engineering; 09-01-2009 at 07:51 AM. Reason: Thanks for looking!
Exactly need more info...I want to mini tub mine at the same time...
