GTO 05 06 Need info on them.
#42
#43
Just do research and don't mindlessly buy a pedders' package.
You can buy better bushings ( complete bushing set ) from energy suspension for much less. Buy superpro or lovells front radius rod bushings. EVERY bushing in the car replaced for about 250-300.
Then choose out your spring/shocks...if you want stiff and handling and a normal spring/shock combo use king springs or lovells springs with koni adjustable shocks....
If you want coilovers use KW or the new BC racing setup
Either way if you follow that plan instead of buying pedders' parts you'll wind up with enough leftover to buy some hotchkis swaybars and the appropriate no bush front endlinks and all of a sudden you have a sweet riding/adjustable car that handles better then something with a full pedders' package and you're at about half-3/4 the cost depending on what options you select.....
But....Like I said....do you research.
