Ls6 cam in later 04 gtos?
Umm that's not what I asked not being a dick but I was asking about the cam....I read that some of the later model 04s had ls6 cams instead of ls1s 207/217 525 lift on a 116.5 lsa
They all had the ls1 cam which is the same as f-bodies. Their was a thread that said the 04 GTO's had a slightly different cam than the f-bodies, but that has been up for debate. When I pulled my cam it spec'd out to the same as an f-body ls1 cam from the later years.
Jeez! I can't believe I did that. I guess my wife is right. I don't listen (or in this case read).
LS1 cam specs-196/207 0.467/0.479;116
LS2 cam specs-204/211 0.525/0.525;116
LS6 cam specs-'01 204/211 0.525/0.525;116
LS6 cam specs-'02+ 204/218 0.555/0.551;117.5
HOPE THIS HELPS
HOPE THIS HELPS
The facts I posted were outta Chevy High Performance Dec 09 issue they decode all Gen III & IV Ls engines and what they were in say in there 98-02 F-body,
97-04 corvette,
04 GTO
97-04 corvette,
04 GTO
hmmm well the cam docter took you for your money, i called gm today and got the specs. intake 204 .496 lift, and exhaust 211 .496 lift 115.9 lobe seperation. very similar to the earily zo6 cam.
I, along with others that have had their stock GTO cam spec'd out, have proven that wasn't the case. Mine was a June '04 build, so it was one of the last ones to roll off the line.
I guess this will never die. Even when there is proof, some people believe what they read....
its preaty funny that this is the first time that i have ever seen some say their cam spec'ed to a std ls1 cam. i have nothing to gain from my post. just giving the truth of the specs straight from gm. i also know that on ls1gto their results were very close to what i found from gm; when some of those gentleman cam doctored theirs.
I did mine 5 years ago and posted what I found. I only did it because of all the rumors going around back then and nobody had done it yet. I had a very low mileage cam and went to go see what it would spit out. I certainly didn't/don't have anything to gain, just facts.
NOBODY has ever posted, as far as I know, anything different when they did their cam either. Please show some threads saying they spec'd the '04 cam and got what you say. I've been on LS1GTO since it began back in '02, so I'm not some noob over there or here for that matter...
The following users liked this post:
oldngray (03-26-2020)
alright, i will do the research for you on ls1 gto, but answer this. if the 2001 ls1s all had ls6 intake s and same cam just like the the 2004 gtos, why did the gto make more hp? 350hp compared to the ss ram air 325hp? also why did they put the blue valve springs on the 2004 gto that was for a .570 lift compared to the std ls1 green painted valve spring that was good to .500 lift?
