Pontiac GTO 2004-2006 The Modern Goat
heads...cam...
Old Feb 7, 2010 | 09:13 AM
GTOdave's Avatar
Default heads...cam...
alright guys,,,noim goin to get heads and a cam..i got the money..what do you guys think will be the best heads and cam...like i heard trickflow are really good...but idk what do u guys think shiukd be the beest im looking for.so far i got LB headers, cold air..a tuner..and exhaust..
Old Feb 7, 2010 | 09:33 AM
batboy's Avatar
Is this a M6 or A4? An A4 will require a higher stall converter and a M6 will probably need a better clutch after a while. What kind of budget and what are your performance goals? Is this a daily driver?
Trick Flow and AFR heads are definitely top notch, but also very expensive. I would check out the Texas Speed PRC LS6 stage 2.5 ported heads. Texas Speed also has some good cam kits too, like the Torquer V.2 for example.
Old Feb 7, 2010 | 10:16 AM
GTOdave's Avatar
its an A4. im looking to get a new converter anyways like..soon. and im lookin to get head and a cam for about 3000 just on head and cam...and during the summer this is my main driver but wont be a daily drive bc i got a truck too..i just want some really good heads and a cam. a mean cam
Old Feb 7, 2010 | 12:03 PM
Peetyz's Avatar
Im very happy with my PRC heads from texas speed no numbers yet....
Old Feb 7, 2010 | 12:31 PM
batboy's Avatar
For a $3k budget, for cam, heads, springs, bolts, gaskets, etc. you might as well forget Trick Flow. I didn't think you could get AFR heads and stay within your budget either until I saw this from Texas Speed (you'll still need the basic cam/head bolt/gasket kit for another $160):
http://www.texas-speed.com/shop/item...d=205&catid=47
Personally, I think you should consider the PRC stage 2.5 LS6 head kit for nearly a grand less (spend what you save on a FAST intake manifold or other mods):
http://www.texas-speed.com/shop/item...d=832&catid=47
Ok, now for what cam to pick. Hard to beat the Torquer V.2 cam. If you want a mean lumpy idle lope, get it with 111 LSA.
Old Feb 7, 2010 | 01:32 PM
tom's2005gto's Avatar
contact Ed at Flowtech Induction. be very upfront with him about your goals, driving habits, and expectations. Ed is the cam & head guru and will not oversell you, but make sure you get the best bang for your buck.
Old Feb 9, 2010 | 01:11 AM
Bring the Noise's Avatar
Trick flow "As Cast" 220cc ls1 heads (part # TFS-3060T001)
They come assembled as a pair for around $1700
220cc intake runner & 80cc exhaust runner
2.04" intake valve & 1.57" exhaust valve
.600" dual springs
You will need to run a set of aftermarket rockers (Comp, Harland Sharp, Yella Terra, Lunati, Crane, etc).
Comp's Gold 1.72's go for $434 on Summit
Contact Ed (flowtech) or Patrick G. (http://guerragroup.com/camshaft_help.htm) and get a custom cam.
Spend another 325 (only until 02/28/10) and get your manifold and tb ported by Jeremy F.
https://ls1tech.com/forums/generatio...g-special.html
so $1700 for heads, around $425 for rockers, $450 for a cam, $100 for push rods, $200 for gaskets, bolts, thread lock, etc, $325 for ported throttle body + manifold.... just a little over for your 3k budget but would give you one hell of a bang for the buck.
Old Feb 14, 2010 | 05:09 PM
GTOdave's Avatar
what do u guys think of these heads..
http://www.texas-speed.com/shop/item...d=649&catid=20
Old Feb 14, 2010 | 05:19 PM
GTOdave's Avatar
havent decided on cam yet..
