VFN Fiberglass hood on car pics
thank you !!!
one more quick question , the support thats kinda in the middle , about where does that lay over the motor at ?
im trying to decide whether to stick with the vic jr and 4 barrel tb , or get the proflow intake
thank you
thank you
that definatley looks amazing, seeing as thats the pin on hood, where did u get those latches for the pin on at? im thinkin about ordering the pin on hood this week now that ive seen it on a car.
After nearly a week of driving with this hood, I can honestly say I am more than happy with it. The fitment, and quality are definately top notch. The only issue I've had to speak of is the turbulence that I was getting from air coming under the front of the hood. It was causing the rear of the hood to shake violently at any speed above 70mph. I fixed this problem by taking a piece of foam approxamately 24"x1" and using 3m double sided tape to afix it to the front center just in front of the hood latching mechanism. This created a seal that is keeping the air from rushing under the hood and causing the shaking. I've taken it up to 130mph now and not had any issues. I am still looking for a cleaner and more "easy-on-the-eyes" fix to the issue. I will take some pics of the current fix and once I find a better one, take pics of that.
how much movement do you have on the hood pins ?
old racers trick i know is using weak valve springs(or similar) on the pins to push the hood against the pin to keep it tight , it does make it a little fun to put the pins in
also ive seen people use 4 pins in the back and front
#32
