guys i need help with this one..
ok guys ive been sitting here for about 3 weeks with out my gto runnin just bc of pushrods..so please someone help me with this one...i got the texas speed kit of heads and cam swap..i got 2.5 ported ls6 heads..it comes assembeld..and i also got the tourqer V2 cam from comp..and i need to know what pushrods i need..they told me to measure them and i dont know how..this is where i need help guys..can u guys give me some advice..id like to get my goat runnin this week.! so please comment on this..thanks again guys!
Put one of your stock pushrods in and put a rocker on it. Rotate your crank to different positions and try to spin the pushrod at different places. If it's really hard or you can't spin it, use the 7.4's. THis isn't the best way to tell, but it works in a pinch.
ususally if a head is milled you put a shorter push rod in in. you will need prolly a 7.375 to 7.35 pushrod. like what was mentioned before rent a pushrod checker and get the correct length.
ok well can i just put the measurer to stock length (7.4) and put it in and crank over the motor and if the rocker bottoms out on the spring and prolly too big?? idk if that would do it or not..
