2004 gto trouble code idle problem !
![Unhappy](https://ls1tech.com/forums/images/icons/icon9.gif)
An engine light on my dash came on yesterday. It idles rough and the exhuast smells funny. I checked the codes and they say it's running lean and is misfiring. Could it be air intake problem (leak) maf or fuel pressure ? I put the stock tune back and same problem still exists. Can any one help?
Didn't find anything loose. I cleared my codes then got another later. lean and o2 sensor no activity bank 2 sensor 1 . Maybe bad o2 sensor? cleared them again and ran it a few miles no more trouble codes so far.
Found the problem. The wire from the passenger side front O2 sensor was torn in two places. I must have ran something over because it tore the plastic anchor clip away and was unclipped. Thanks for the tips guys. I'm also lucky it was on the passenger side because the drivers side has alot of stuff in the way.
