header install on an 05 gto a4
just wondering my buddy has an 05 gto and we were wondering how difficult a header install would be on it and what the main issues would be?
We also are wondering if he should get aftermarket heads or to just keep the stock 243's and get them port and polished?
The MAIN issue for me was the power steering rack. This must come out. Whileit is a PITA, its not as bad as people make it out to be. Two of the PS lines must be removed from the rack. And after that, there are 2 bolts, one on each side, holding the steering rack to the K-member. Will a get a bit messy as well. Stock exhaust manifoldswill come out through the top of the bay, new headers will need to goin through the bottom. The steering rack was the only main obstacle.
As for heads, porting is the cheaper alternative, obviously. While some people swear by this, I will be getting some nice TF or AFRs when the time comes. Porting without a doubt, does work and gains have been proven time and time again. Take that as you will.
If you go over to LS1GTO, there is a write up/sticky that was very useful to me. Or GM performance had an article on an 04 that helped a little bit as well, titled "Back In Black".
Hope this helps.
Hope this helps.
I didn't have to take my rack out we just removed the lines and dropped it, what took us a minute to get back in was the steering knuckle as it was not lined up properly. It's very straight forward after the rack and knuckle are handled.
Like mentioned, the Knuckle has always caused the most problems for me. I have done about 8-9 of these and that was the biggest PITA. The rack and the lines never caused much problems. Didn't even use stubbies, just did the bottom line from the bottom of the car and the top line from the top.
Anyone have problems with the top of the steering wheel not being at 12 o'clock with the wheels pointed straight after dropping and reinstalling the rack? Or is that the issue about the steering knuckle that was mentioned above?
Hope this helps.
Try not to move the steering wheel and tires too much and you should be ok. Yeah while getting the knuckle back together this is usually the time that you can do the most wrong with the steering wheel alignment.
OP, GL on your upcoming venture.
Dont worry about the heads till you up grade the cam, unless your going with a power adder like a supercharger and want to run lower compression with the stock cam. Otherwise everything else you need was mentioned already. Good luck.
i have been reading all the responses and i really appreciate the feedback there is alot of useful info and tips. i relayed everything to my buddy and as of right now this is going to be a project over this coming winter, he is trying to get his full exhaust first then he wants a cam. so as soon as everything is ready to go i will make sure to get pics as we go ahead into the install.
It's very common for the steering wheel to be off a little after dropping the rack. All you need to do is loosen the two big rack bolts and move the rack over one way or the other and tighten it back up. It might take two or three attempts until you get it perfect.
How do you get the PS lines reconnected once the new header is in. And do you have to have the front wheels off the ground in order to get the rack reinstalled. I am having these issues.
