LCD Cold Problem
Anyone ever had the problem with the cold that messed up the cluster LCD screen? I thought that it could go back to normal but it's not freezing anymore and half the screen is still missing. Not really bad but just annoying! Anyone had this problem or know a fix? Maybe a new LCD screen? May stop by the dealer in a couple days.
I have seen a lot of dimming of the cluster before but I have never seen half of it go out. Sounds like there might be an issue with the pin connections. Have you had any modifications done the the cluster it self? If it were me I would take the cluster apart unless you have a warranty on it. There was a issue a while ago where the cluster will surge but a reflash took care of the issue.
