06 GTO M6 Clutch Suggestions.....aftermarket clutch guys come on in!!
Well the ls7 flywheel has raised points on it that the pressure plate bolts to that arent on any other flywheels. So unless youre aftermarket one looks like this.....you need to get one.
(aftermarket)
(stock)
Don't trust what GM has to say...
(aftermarket)
(stock)
Textralia OZ700 clutch and I have been through a few clutches; 4 to be exact. The Tex feels exactly like stock and will hold over 550 ft-lbs. Other clutches mentioned in this thread have a very heavy pedal and all that does is push your crankshaft into the thrust bearing. The key to any clutch is proper installation in terms of shimming.
I found a clutch manufacter from Australia that has been building clutches for our cars down under for years now. I spoke with Manitc and had them send me one of their clutches. I met them at SEMA this past year and their products look great!
I'm getting ready to put the clutch into my car here really soon, so I'll do a write up on the install and performace once completed.
