GTO going on another diet
#45
Hey mark...
How are you doing and your project, have you weight your car jet, or been to the track, pls +1 for update, as for me diet paid off took off 520 lbs,. down to 3,400 with 1/2 tank of fuel and minus driver, i know is is not that much but i added 3.90 gears to complement and feels like is paying off, hope you are well and having fun Sir, God Bless David.
#46
For some reason I haven't been able to get Photobucket to load lately, but......
I've got the cold air/ ram air intake tube done, radiator mounted, shifter and linkages mounted, heater box and heater lines mounted, wheelie bar and rear anti roll bar mounted, switch panel made, gauges mounted, lots of the wiring done and dropping the driveshaft off today after work to get a new 3.5" longer tube put on it and balanced. By the end of the week I hope to have the exhaust done and more wiring done (need to wire in the fuse box and relay box).
So it is coming along pretty good if you add in the fact that we got a 18'x 36' pool and built a huge deck on it to keep her and the kids happy lol
#52
I have all the interior parts, just have to finish the rewire so I can put the parts that still fit back in lol
Went out to the garage about 1am and started working on her again....got the new driveshaft painted and put in, exhaust back up in with all the new hangers, set the gas tank in and refitted the filler neck, put all the 4link bolts in and tightened them down, then took a break and went to bed about 4am. Next on the list is tweak and rebend the main fuel and brake line that run front to rear.
#56
Hey Mark...
Man didn't realize how far you have come, and still make the a pool?
The wheelie bars look great, still will hang the wheels, great job and effort, i think turbos not necessary for 9. flat passes.
