Picture Request; emissions equipment sticker under the hood
Can someone preferably with an '04 GTO do me a favor and take a picture of the emissions equipment sticker that is under the hood? It is on the black plastic trim that covers the top of the radiator.
I am using an '04 GTO LS1 for an engine swap and would just like to have this so i have all the correct emissions equipment for the DMV.
I have a 04 gto i will be more than happy to do it. Wont be until later this afternoon. If someone beats me to it ok but i will check post this evening and if no one has i will do it for you
Thanks to you both, i need one close up where everything can be made out if possible (thanks anyhow Rob!). I am pretty sure i wont need it, but would like to have it incase i run into any problems with amending the title at the DMV to reflect i am going from a 4cyl to a 8cyl .
As i understand the GTO does not use a smog pump like all '02 and earlier LS1 equipped cars. Just want to be able to prove that incase i need to have an inspection where the emissions equipment is checked.
