Race Stars are on the goat
^^ i got open ends for my rears with arps. turns out i didnt need them. could have went with the closed end lugs.
i got more pics today but photobucket is being gay. ill try to get them up soon.
#32
The banjo bolt for the brake line to the caliper needs to be ground down at an angle, it hits hard enough that you will ruin the rim if you don't grind it down.
Also, the brake hose has a short steel section coming off the caliper that needs to be bent in and down to get the brake hose to clear the rim.
I will post a pick of my wifes gto with m/t 8.5x26-15 ET Drags sometime next week.
Side note, the washers that come from Race Star are cheap junk, and these rims are made in China
#35
Yes I believe I mentioned the mods required to make the wheels work on the first page. You also will need to check the inner fender in the rear. It's the black plastic thing in the rear fenders. I had to trim mine a little but my tires are wider than what you are going with.
#36
#37
i got these same rims on mine except i did a 15x8 with a 5.5bs on the rear and my rears poke out kinda annoying also with the m/t sportsmans on the front they also poke out drives me nuts btw how do u like thoes hosiers??
#39
How much was this set up 402 goat? from wheels and rims? You think you might know any named brand companies who sell these rims too? The pro stars look great on GTOS in general
