Pontiac GTO 2004-2006 The Modern Goat
Tampa Tuning for Dyno Tuning and Street Tuning pricing
Old 09-12-2012, 08:28 PM
Tampa Tuning's Avatar
Default Tampa Tuning for Dyno Tuning and Street Tuning pricing
From now till December 15th, Tampa Tuning is offering a Saturday dyno tuning out the door price special with the dyno time included.
To dyno tune a Camaro, Corvette, GTO from stock to bolt ons the cost is $350.00
To dyno tune a Camaro, Corvette, GTO with aftermarket internals (cam) $420.00
To dyno tune a Camaro, Corvette, GTO with Forced Induction $500.00
Tampa Tuning will performance:
Read and reprogram your PCMs settings and perform real time scan diagnostics for the best results
Increase power enrichment rate mode
Examine and change timing tables for additional horsepower & torque gain
Optimize your vehicle’s Air and Fuel Ratio monitored with a wideband
Reduction of Intake Air Temperature table (heat soak prevention)
Desired rev limiter adjustments
Park, neutral, and in- gear idle adjustments with and without A/C active as needed
Adjust power enrichment delay
Engine torque management system reduced
Transmission torque management system reduced
Transmission shift points enhanced
Transmission shift times reduced
Transmission shift firmness enhanced
Skip shift deleted (CAGs 1st to 4th shift)
Fuel injector rescaling for aftermarket injectors
Cooling fan activation temperature recalculated
Perform speedometer recalibration for rear gear ratio and tire size change
Turn off check engine light and remove trouble codes
Neutralize rear oxygen sensors that cause CEL
Idle calibration
Start up airflow calibrated
Long Term Fuel Trims dialed in
Open and closed loop calibration for optimized results
Disable Displacement on Demand ( AFM)
...and other performance calibrations to achieve maximum safe results
You can reach me at Tuning@TampaTuning.com
or call for appointment 813-727-8720
Burn your tires not your wallet
www.TampaTuning.com
Phil
Old 11-06-2012, 09:23 PM
Default Camaro Corvette Firebird WS6 GTO G8 GM Truck performance Tuner in Tampa
mid week bump to save a buck
Idle calibration
www.TampaTuning.com
Phil
Old 11-11-2012, 06:36 AM
Default camaro corvette GTO performance tuner in Tampa Orlando
Sunday Morning recovery bump
Idle calibration
www.TampaTuning.com
Phil
Old 11-20-2012, 05:55 AM
Default Camaro Corvette C7 GTO performance Firebird Truck tuner in Tampa Orlando
We tune everything from performance vehicles with forced induction to my wife's V6 family van chevy uplander to big GM Trucks.
With GM adding AFM to more of their performance line, our business has been packed with automatic guys. I cant wait for the new line of the C7 corvette. The Camaro guys hate AFM/DoD and it brings in a ton of business.
you can Email me with questions at Tuning@TampaTuning.com
813-727-8720
or visit our website at www.TampaTuning.com
Phil
Idle calibration
www.TampaTuning.com
Phil
Old 11-30-2012, 05:38 AM
Default Camaro Corvette GTO CTS G8 Firebird Truck performance tuner in Tampa Orlando
You can alway reach me at
813-727-8720
Camaro Corvette GTO CTS Firebird Truck performance tuner in Tampa Orlando
Idle calibration
www.TampaTuning.com
Phil
Quick Reply: Tampa Tuning for Dyno Tuning and Street Tuning pricing
