Direct Replacement 2x Subwoofers
I replaced mine with JL ZR 800CW. Had to trim the hole and put a 1" MDF spacer between the deck and the mounting ring. Those aren't really subs they are midbass though from about 50-250hz. For actual bass I'll be going with a 12W6v3 in the spare tire location.
The factory amp is pretty worthless and you should ditch it imo.
