d1sc gto question
I have an 06 a4 with a d1 with a 3.55 pulley. it also has kook long tubs and a blower cam (not sure the specs), 80lb injectors, 255 fuel pump. I know a few other cars with close to the same setup and bigger pulleys making more boost and more power (only made 10psi and right around 560rwhp on that set up). I was wondering could something else be holding the car back or is that about right for that setup? I thought the trans and converter were holding the car back so I upgraded them to a ptc trans/converter and added a meth kit and only got about a 20rwhp gain (584rwhp @ 10psi). I was wondering could something else be holding the car back or is that about right for that setup?
What kind of dyno were those figures on? Dynojet? Mustang dyno? Dyno dynamics? If you're comparing dynojet to mustang figures the mustangs read lower. Either way 580hp is definately more than a p1sc would make and seems ballpark, especially through an auto trans.
Getting rid of the LS2 intake manifold and TB would help pick up some more power. You could also try running E85. Other than that, a built bigger cI motor and/or an upgrade to an F1 Procharger.
But, it is on a dynojet. Its still in the shop getting the meth kit redone and finish the tune up on it. But my tuner told me yesterday that the 584 number was going o stay about the same.
I was thinking about going to e85 but decided to just go with meth for now seeing if my bottom end would hold it. I am also looking into different intake and tb now.
Here in Texas at least E85 seems prefered over meth. I have seen completely stock internals 370Zs with bolt on pick up whp with E85. Plus, from what I understand Methanol is bad for your motor where as E85 actually runs cleaner than 93, the only downside of course being fuel system requirements and gas mileage.
308-323 whp just changing over to E85 on an N/A car. On a boosted car you will pick up significant power.
http://www.the370z.com/engine-drivet...-370z-e85.html
Here's a 402 GTO running E85 with a procharger and 13psi: 720whp
http://www.facebook.com/photo.php?v=...type=3&theater
Trust me, the LS2 intake is the worst LSX intake there is. A FAST or a Cast intake with an elbow and a 102mm TB is going to pick up power, it might push you over 600whp. The FAST you have to watch out for with high boost levels though.
