want easy rolling wheel hubs for the front
My wheel hubs are not what I will consider performance kind, just hard to turn, will be so much better to have the grease changed to 50 weight oil per say, does any one knows if the hubs can be opened and reseal with lighter lubricant in it, or any performance pieces available thanks in advance, David.
__________________
__________________
The worse that could happen is may hurt the wheel bearings but I don't think so, just think the rear wheels on a hard straight diff are lubricated only by gear lube in must cases, and chances are unless the bearings go dry you never have to bother with them. My knuckle head tells me there's a 10th or two to be scavenged there.
Yeah it would be worth a try the bearings would last longer in an oil bath setup. With them being sealed and pressed in it would be hard though. Maybe you could get someone to fab-up some spindles and bearings.
You are rite but in don't have lube thank you, what I have is paste and been high heat never liquefies so it does take extra effort to spin and beside it tends to dry up and deteriorate, those my advantage if can help it, win loose or draw I will try on all four wheels.
I do welcome your input and ideas though, thank you.
I know I will be screwing around with this till I get my way, and I usually do.
