2004 GTO white shifter boot
Ive been hearing alot of road noise from the shifter boot and did not know why. I pulled off the cover and discovered the white boot was all torn up, So i thought i could just order a new one online no problem. I tried ordering the boot from three different GM websites and are all on back order and have no idea when i could be getting one. Does anyone have a white boot or know where i could find one????
Thanks!
Thanks!
I am seeking the same exact thing and for the same reason. Can't find them anywhere. It's a straight forward part but none to be found. I would accept some type of substitute (that fits exactly right) but can't find that either. Any suggestions woudl be great. Hard to believe there is no aftermarket options. I've been told that no one knows if GM will ever supply these again at all. It's on back order but no ETA or lead times are available. Mine is a 2004 manual shift GTO. Photo attached... GM part number is 92169186
