p0507 diag help
p0507 diag help
Pulling my hair out here... Cleaned throttle body and maf when I re oiled my filter.. no oil on maf checked many times. Trac light off message comes on and my idle surges when coming to a stop and is constant at 1000... No vacuum leaks that I can tell. This is the weird part.
Blocked off PVC system( port behind throttle body) and idle went down to normal (820-835 rpm) until you touch the gas then idle returns to 1000. I would just love a diagnostic procedure on the throttle body and the code it self and any insight would be awesome.
