gto wheels
so it works the reverse of what I remember. I always thought the higher the positive offset the further away the mounting surface from the center line of the hoop. guess I need a refresher, its been a while since Ive had to shop for wheels
got them on love them, but I have some rubbing issues, but I almost think that is due to rear spring sag more than wheel/tire size. should probably roll the fenders, but I think i need to look into a better spring shock combo.
also any leads on getting some pontiac center caps? did a search on da google and it mentioned a few guys had some custom made but no info about who made them.
#32
Thanks found them they make a lot of stuff for these cars.
seems like the coil spring options are a bit limited these days as well
#33
Tell me about it. I'm still rolling on Pedder's drag springs with BMR drag bags stuff in them.
I've considered switching over to BC Coilovers on the rear to match my fronts, even thought it isn't a true coilover design.
#34
I looked at those myself, Im just not wanting to dump that kind of money into a daily
I was looking at tiens or H&R's but it seems everyone but eibach is okay. I figure it doesnt matter what I put on the back it will likely set higher or the exactl same is it doesnt now. I can pretty much squeeze my finger between the tire and fender on the driver side and have more space on the passenger with my 18's.
#35
#36
It rubbed a couple of times but that was when I had sever sagging issues. If I hit a hard bump it still bottomes out and rubs a bit. I have access to a fender roller and I had been planning on doing it just to get it out of the way. So it depends on your ride height mostly.
I went 18's on all 4 corners for what its worth.
#38
that would depend on the offset, since its rubbing on the outside. If you are at stock height would be fine either way I think. For isntance the pic you quoted vs what mine looks like id say that car has another inch of clearance above the tire.
