trailblazer ss driveshaft in a gto
ive been trying to research lenghts and what not to see if this swap is possible... ive seen that the tbss shaft is 52 3/16 long and the 04 is 52 1/2 long.... what would be needed to make it work?
You're absolutely right... And I realized that which is why I'm trying to find an alternate solution....
I used to make carbon ds kits. I will tell you that it's extremely expensive to gather top shelf pieces and not cut corners. You can easily hit 2000 for a cf deal. Luckily, one company has decided to mass produce those for nearly half the cost. They aren't as strong or unique as what I used to make, but many have been very happy with them.
Your biggest issue is going to be the rear yoke. You may be able to source a direct-fit flange from the Driveshaft Shop to bolt the shaft to the rear, but I don't know what they would charge for that. Most of the money for the aftermarket shafts is tied up in the pinions.
