2004 GTO MAF questions
Hello all. I have a question regarding swapping a 5 wire MAF into my 2004 GTO that I've just swapped a 5.3 into. Previous owner cut the 3 wire MAF plug off and spliced a 5 wire plug into it....however they were only using 3 wires from it and appeared be using the stock 2 wire IAT sensor as well. The 5 wire plug is different from the plug that my MAF uses but I have the correct pigtail for it.
Question 1 ... anyone know what wires do what so I can wire this correctly? The wire colors are different from the harness to the MAF that I have.
Question 2... should I just wire it to just use the 5 wire MAF as MAF only or use the integrated IAT sensor and not use the factory GTO iat? I still have the GTO IAT plumbed into the air inlet.
Here is a few pics of the connectors I have.
First pic is factory wiring that they spliced the 5 pin connector on. Colors from left to right go...
Harness side..........connector side
Black/red jumper to Black
Pink. To. Red
Brown. To. Green
Second pic is 5.3 MAF
Colors left to right
Yellow...pink...black/white jumper....tan...black(possibly dark purple?)
Third pic is 04 gto IAT plug
Wires left to right
Brown......green/pink jumper
Edit....found more info...
neither one of the vehicles listed in the pinout are exactly what I have but the colors seem to be correct... so judging from this pinout I found I should wire it...
Harness side ......MAF pigtail
Brown/white to yellow
Pink To Pink
Black/red To Black/ white Factory harness and spliced plug 5.3 5 wire MAF
Factory 04 IAT plug
Pinout thats closest to the colors my 04 gto harness and 2003 5.3 MAF are.
