05 TT GTO intermittent stumble/ dying
hello all , I have a 05 gto that I did a full forged TT build on and everything was going well thru the tuning process and all of a sudden car is acting up . It will stumble at idle and sometimes die and seems throttle has no input when it's trying to die either.. if I take off is 1st gear normally and about to push clutch in it engine will cut off it seems like then right back on .. seems to happen more when car is warmed up .. this seems like something electrical and definitely not tune related .
Car does have e40 ecm with ID1700x injectors with a scaled SD tune
Any thoughts and or suggestions would be greatly appreciated. Thanks.
Mine had the same EXACT symptoms when the MAP senor was going bad. Are you running a 2.5 bar MAP? Also, how much was your tune scaled and did you make sure to scale every single table with airflow (there is about 30 of them)? Or did you just change the Stoich table for scaling?
Ill check the IAT sensor as well.. ( spliced into my old maf plug , I believe its the diy autotune one gm fast responce) i do have another 2.5bar map on the way as well . I do have quite a few logs since I always log everytime im in the car .
