Pontiac GTO 2004-2006 The Modern Goat
10.50 Bmr Gto
Old 10-05-2004, 05:57 PM
LS1Tech Premium Sponsor
BMR Suspension's Avatar
Default 10.50 Bmr Gto
We finally made it back to the track this past weekend and got the car down to 10.50@129mph. We made 3 passes that day, a 10.56, 10.54, and a 10.50. This was on a 275/40R17 BFG Drag Radial and stock wheels. Our ultimate goal is to be a member of the single digit club but we are fighting a race weight of 4120 lbs We really want to do it on radials to and I think if we can get a 1.45 60 ft. out of it and squeeze another 50hp of juice, we just might make it there.
Here is the VIDEO
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
Old 10-05-2004, 06:02 PM
Administrator
unit213's Avatar
Pretty damned amazing. Did you do any internal work or just replace the blown head gasket?
Old 10-05-2004, 06:15 PM
WILWAXU's Avatar
Looks like BMP is working! Nice 60ft for that weight!
Congrats Guys!
Old 10-06-2004, 01:21 PM
Sabre002's Avatar
Damn 4120, you got a K member for that goat in the works? or anything else to help with the weight?
Old 10-06-2004, 04:32 PM
Sport Side's Avatar
much better launch than your last video. was better traction the only change since then?
sweet times.
your goat is heavier than my truck.
Old 10-06-2004, 10:28 PM
It now has an iron block 408 with much better internals. Turns out the blown head gasket was actually a hole in a piston
__________________
Allan Miller
President
BMR Suspension
(813) 986-9302
Old 10-06-2004, 10:41 PM
We have been looking into a weight reduction but this car is baffling. After speaking with a few race teams, it seems that a lot of the weight is in the insulation and sound deadening, as much as 130 lbs! The factory K-member actually weighs less than an F-body k-member. The most we could save with a tubular version is 20 lbs. tops. A lot of other extra weight is in the independent rear suspension and heavier gauge (than American cars) floorpan and frame material.
Basically to get this car down to something like F-body weight you would have to lose the interior and air conditioning. We plan to get some lightweight race wheels and possibly build a tubular K-member but we don't plan to strip the car down, it's still completely streetable at this point.
4120 was with driver, the car weighs 3970. The added weight can be attributed to subframe connectors, rollbar, two 25 lb NOS bottles, and the iron block which adds another 80 lbs. by itself. Most GTO's weigh around 3750 stock.
__________________
Allan Miller
President
BMR Suspension
(813) 986-9302
Old 10-06-2004, 11:25 PM
Sabre002's Avatar
oh ok I was about to say. I did not relize you had the Iron block in it now. Why did you go with the iron block Just wondering I mean was it not heavy enough for ya lol. would the C5R block not be better or was it not worth it for you guys to waste the money on one of them? oh and what did you up the nitrous shot to now?
Old 10-07-2004, 05:51 AM
CSiJason's Avatar
That is sick fast!
Any problems with the rear diff yet or did that get swapped out a while back?
Old 10-07-2004, 04:47 PM
Yeah, we didn't really want to add more weight but we wanted something sturdy and $750 vs. $7K for a block just justified the extra 80 lbs. We had the nitrous on the old motor jetted to 200 additional HP based on the chassis dyno results. We haven't dyno'd it since but we went up a jet size with the new motor so it's probably somewhere around 230-250 now. We can actually go all the way up to 400 HP jets if we ever need to but would probably add another stage instead.
__________________
Allan Miller
President
BMR Suspension
(813) 986-9302
Old 10-07-2004, 04:54 PM
Originally Posted by CSiJason
That is sick fast!
The diff itself puked the posi a while back. We now have a spool in it just so we could continue to race until the Diff Technics 9" IRS comes in. Hopefully when that's installed along with some new Mickey Thompson Drag Radials we can leave the line on some nitrous and get our 60 ft down into the 1.40's. That alone could get us into the low 10's, then just a little more juice and single digits
__________________
Allan Miller
President
BMR Suspension
(813) 986-9302
Old 10-07-2004, 06:11 PM
Sport Side's Avatar
BMR is rockin it!
good job with that project. keep up the good work
Old 10-13-2004, 07:18 AM
beertestr's Avatar
Nice run on the track. I was looking at the sig, and you mention a BMR swaybar, but I did not see it on your website. I need to cure some understeer issues with my GTO on the road courses (you know, when you use the steering wheel to KEEP the car from going straight)
Is the bar still available?
Also, what happened to your stock GTO wheels? I'd be interested in them if ya wanna sell em..PM me on that.
Thanks..
Old 10-13-2004, 09:18 AM
Thanks..
The swaybar we are using is a chrome moly adjustable drag style prototype that we are testing. While it has helped with understeer, it was primarily built to help "tune" our launch at the track. The rod ends used for this type of bar are not recommended for a daily driven car so we probably won't be duplicating the bar. Later we may make larger diameter factory style bars, it just depends on the market demand.
We will probably be keeping the wheels for reselling purposes, sorry.
__________________
Allan Miller
President
BMR Suspension
(813) 986-9302
Old 10-13-2004, 12:34 PM
Brains's Avatar
If/when you want to unload the rims, I might be interested if I haven't bought a set yet...
Old 10-13-2004, 08:03 PM
GTA91's Avatar
AWESOME! I can't wait to get a LS2 Goat... I already kinda miss my '04 that I traded in
*What exhaust is on that thing? It sounds awesome!
Old 10-18-2004, 05:35 PM
beertestr's Avatar
I'd love more rear bar for the road course. Did you fab your own bar (gee where would you guys find fab tools) or mod an off the shelf unit to fit. I am not worried about the rod ends, I was thinking of going that route for the front bar to aid in steering response. I can fab some of my own stuff, so modifying your prototype bar with a urethane endlink is not a problem. I just can't do much bending, as I currently only have a bending shoe for a 1.5" bar.
Oh, and while you guys are fabbing stuff, camber plates would be nice too
Didn't hurt to ask about the wheels though..
Old 10-18-2004, 06:10 PM
8 SEC SLOPPY SHOT!!!
tuff's Avatar
Are you running a DP setup for the nitrous.And if you are what kit.
Old 10-18-2004, 10:59 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Very impressive....especially with the IRS.
Old 10-19-2004, 04:03 PM
98 SNAKE EATER's Avatar
nice Run
Aztek T/A WS7 & 70 RAM AIR IV T/A
Moderator @ LS2, FAST LS1, FUELSLUT,
The F-Body Hideout, LS1Turd & ChopperForums
Quick Reply: 10.50 Bmr Gto
