Pro Stock GTO Earns First Win
Greg Anderson scored the GTO's first win in Pro Stock last weekend in Sonoma.
From www.nhra.com...
Pro Stock-Final Round
SONOMA, Calif. - SUMMIT FastNews - Results of final, round 4 eliminations in Pro Stock at the NHRA POWERade Drag Racing Series, 18th annual FRAM-Autolite NHRA Nationals presented by Supercuts:
W/L Driver RT ET Speed
(W) Greg Anderson (Summit Racing Equipment GTO) 0.033 6.732 205.63
(L) Kurt Johnson (AC Delco Cobalt) 0.016 6.760 204.23
Weather conditions: air temperature 90 degrees, relative humidity 32 percent, barometer 30.35 inches, adjusted altitude 1,846 feet.
Anderson holds a 16 to 8 advantage over Johnson in head to head match ups and nine to one in finals, but the last time they met in a final was in St. Louis and Johnson won that one. Johnson is out of the gate first and the lead until just before a 1000 feet when Anderson was able to drive around him. Anderson will leave with the points lead, a 50 point lead over WJ.
http://www.gregandersonracing.net/ev.../0530-1784.htm
http://www.gregandersonracing.net/ev...0530-2944D.htm
http://www.gregandersonracing.net/ev...0530-2949D.htm
http://www.gregandersonracing.net/ev.../0530-3527.htm
http://www.gregandersonracing.net/ev...0529-2230e.htm
http://www.gregandersonracing.net/ev.../0529-2094.htm
http://www.gregandersonracing.net/ev.../0529-1906.htm
