Does the GTO use similar senders for the gauges?
Does the gto use similar signals for the 4 gauges in the cluster as an f-body? Speedo, tach, temp and fuel level? I guess what Im asking would it be possible to use a gto instrument cluster in a 98 camaro? Just concerned with getting the 4 main gauges to work.
Cluster pinouts would be extrememly helpful.
thanks guys
thanks guys
No chance in hell, unless you want to swap the PIM and the BCM into the Camaro; the GTO cluster reads UART data. However I can make the bootup logo say chevrolet lol
hmm so the gto is different than even the vettes? Ive got a 98 vette cluster that Im pretty sure will work(except the oil pressure gauge) just by hooking up wires from my pcm to it.
