CAGS skip shift install question
Need a little direction, where under the hood would I find the white connector "A" plug by the transmission? Do I need to go under the car for this or is it accessable from the top?
Sorry for being a dunce, but I do not want to be pulling apart things i shouldn't be.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Originally Posted by Nathan
your transmission isn't under your hood...
you'll need to be under the car to connect it.
Thanks for the answer to the so called 5 minute easy install.
http://www.installuniversity.com/ins...sity/index.htm
Look at the install documents (top left of page).
