Pontiac GTO 2004-2006 The Modern Goat
10 Sec GTO
Old 11-19-2005, 02:35 PM
slider417's Avatar
Default 10 Sec GTO
Ok guys..here is the question..is it possible to get a GTO into the 10's and still be streetable without any FI.. so is a 10sec NA GTO possible ??
and if so, what would you need to do it... I just came into some money and I would like to make this my winter project..
I'm in NJ , so I'm thinking of stopping by CARTEK and hearing what they have to say..
Old 11-19-2005, 03:50 PM
Nick98Z28's Avatar
A 10 second N/A GTO? i hope you've got lots of cash buddy!
Old 11-19-2005, 04:59 PM
10 & 11 Second Club
Caveman's Avatar
Cartek has built lots or fast 10sec streetcars, for a GTO to go 10s NA it would have to be pretty radical. At such a heavy raceweight you`d need a built bottom end, huge cam, very expersive stage3 heads,a very loose converter, and every susp part BMR makes.
Old 11-19-2005, 05:03 PM
BlueSix's Avatar
A 408 and some good driveline parts should get you there.
Old 11-19-2005, 08:54 PM
CSiJason's Avatar
You could do it with a decent engine and a bottle. Who said N/A streetable couldnt use a little help at the track from good ol juice?
On that note, a mostly stock 04 is running 11.70's localy on DR's and a little help.
Old 11-20-2005, 07:34 PM
JS
JS's Avatar
Cartek Stroker will do it along with proper verter and or clutch,tires etc
Call Julio and talk to him,He's a very good builder of fast LS1's...
Old 11-23-2005, 11:53 AM
Forced370GTO's Avatar
why not use FI?
Old 11-23-2005, 01:06 PM
old and good's Avatar
Why not just put a turbo system. i think it wuld be the easyest and cheapest way to get there and still retain good drivability
Old 11-23-2005, 02:34 PM
Durien's Avatar
call cartek up.... they build some awesome stuff!
Old 11-23-2005, 03:26 PM
NYTIGER's Avatar
If your willing to lighten the car it could be easy. But you'll probably snap the IRS so while your at it you should put a Moser back there.
Old 11-30-2005, 12:24 AM
MyGoatBites's Avatar
408, stage 3 LS6 heads, manifold and a big TB, big injectors, decent sized cam, well tuned (call it about 12k so far). Then clutch, driveshaft, half shafts, axel stubs, spirings, shocks, something sticky on the ground (call it another 6k at this point).
Give or take 20k and considering you could do all the work yourself...that should put you in the 10's in a goat. I actually sat down and figured it out one day trying to get fast enough to run against my dad's turbo myers manx. (340hp in a 1200 car). I might be able to catch him, I would end up divorced and sleeping in the car...but the look on his face would be priceless. I am still trying to figure out if I should risk it
Old 11-30-2005, 01:00 AM
blewbyu's Avatar
Call CARTEK
Quick Reply: 10 Sec GTO
