04 GTO with Electric Fans Stuck On.
Hi Board. Been a lurker here and on the lsgto site for the past 2 weeks since I bought my 04GTO. I have a problem my electric fans are both stuck on. It started this afternoon I took of the negative bat cable and left it off to keep them shut off. But they are runing constant I had this happen one other time but I drove it some and it went away. Has anyone else had this issue and if so how was it fixed. Thanks for your tim
11 Second Truck Club
I'm no expert, but my 1st guess would be a stuck relay since that's easy to check under the hood.
I'm not familiar with Gto's but you should find some relays in the mounting block under the hood have the same part number. Try swapping them.
Good luck.
Good luck.
Hi thanks for the reply its forsure a stuck relay I oulle the 2 relays beat them up all day at work an nor problems since. I have ordered two more they rin about $15.00 each at the dealer. They only fit GTO models so no one carries them it must not be a huuge problem since the delares are not forced to stock this one, Thanks for all your help
