10 sec APS 05 GTO
10 sec APS 05 GTO
Hey guys, thought I'd post the latest:
60'...1.82
1/8...7.16 @ 104.3 mph
1/4...10.89 @ 133 mph
This was at 11.5 psi boost. The car is pretty heavy, and I'm still using the stock wheels. Rear tires are Nitto 275's. They kinda suck...
The motor is basically stock LS2, with the exception of a custom turbo grind by AZPS. Thanks to NicD's tuning ability and working after midnight to finish it.
The new Edge convertor helped tremendously in trap speed, as the previous best was 126 mph with a too loose Vig3600.
I was hoping to try more boost, but the waste gate springs won't allow it. I might switch those out, but I don't want to push my luck with the stock engine.
60'...1.82
holy crap!!! that is friggin movin!!!
All I would be doing is maybe upgrading the suspension and throwing on some fatties and skinnies and lighten it up and then see what she will do. all those should get it down in the low 10's. Hell, drop that 60' to a 1.60 and your talking a 10.50!!!!
60'...1.82
60'...1.82
Peter
Best I ever did with Nittos was a 1.71 60ft.
With the A4 you should have 1.6 60ft times if you can get traction. Roll your fenders and put some 275 M/T drag radials on stock 17" rims.
