Installed Drag Bags yesterday
drag bags
i got mine from ebay didnt remove the bump stops they went in through the side and air up from the side, no more wheel hop im running 20 in min all the time i gained about 1/2 to 1 inch in ride height now i think i can run some wider meat back there
don't mean to thread jack here, but i'm intrested in getting this done on mine, but i would like to know what times is everyone running , when u feel the wheel hop. and what were the 60' that u were getting when u installed the drag bags.let me know . josh
I ran two schrader valves into the trunk through two pre-existing rubber grommets. Mounted one on each side by the plastic trim pieces holding the carpet to the quarters. Have to post some pics later. Rolled my fenders and have the drag bags set at around 7lbs. Never had any rubbing w/my 19x9.5's (275/30/19 40mm offset).
