t-stat
And definitely have your cooling fans programmed when you do the new thermostat. It'll keep them from coming on and off so often, and will keep temps low with them running a little more often.
YOU HAVE TO PROGRAM THEM TO MAKE THE FANS COME ON EARLIER AND YOU WILL NOT HAVE ANY LIGHT ISSUES. SOME PEOPLE HAVE HAD THEM AND SOME HAVEN'T. BUT IF IT DOES COME ON AND YOU CANT PROGRAM IT THEN DISCONNECT THE (-) BATTERY TERMINAL FOR ABOUT 5 MIN. AND IT SHOULD REST IT. HOPE THIS HELPS
