Pontiac GTO 2004-2006 The Modern Goat
bolt pattern
Old Aug 19, 2007 | 03:05 PM
Agt. Orange's Avatar
Default bolt pattern
will rims on A 99 vette fit on my 04 gto?
Old Aug 19, 2007 | 04:44 PM
GTO1_OHIO's Avatar
The 04 Bolt pattern is 5x120 so if your vette wheels are 5x120.65 you can get them to fit. The main thing to be concerned about though is the offset. The GTO is +48. Put too large an offset in the front and you'll hit the strut with the tire and get "Strut Rub" The other thing to be concerned with is the bore diameter....you may need to get hub rings to stay hubcentric.
Old Aug 19, 2007 | 08:21 PM
flyin red TA's Avatar
Replica vette wheels with the right size and offset fit. Factory vette rears won't work.
