Pontiac GTO 2004-2006 The Modern Goat
Sputtering when I let off the gas
Old 05-30-2008 | 10:37 AM
jray1's Avatar
Originally Posted by TIMBO0566
Last weekend I installed a set of JBA shorty headers with a set of stainless works 64/65 retro cat back 3 inch exhaust. I also put in a LS-7 clutch flywheel, stainless steel braided lines. I also installed a gmm rip shifter & bosch plus 4 spark plugs with new wires. Well when I let off the gas to change gears I'm getting a lot of sputtering. Is this normal or is it because the battery was dis-connected and the computer was reset? Will this sputtering go away or is it permanent? Has anyone else had this problem?
I just leaned my tune out a little and most of my popping on decel is gone.
Old 05-30-2008 | 03:10 PM
dsmtrance's Avatar
Originally Posted by Drew04GTO
If by sputtering you mean missing then its your fancy new bosch plugs.
I was gonna say the same thing
Old 07-07-2008 | 11:46 PM
TIMBO0566's Avatar
My popping sound was an exhaust leak, I used red high temp silicone on every joint on my exhaust and the popping went away. Thanks for all the help guys, This is a really great site for help & info.
Quick Reply: Sputtering when I let off the gas
