Project Comments & Discussion Use this forum to discuss Sponsor projects.
Need help mounting an ls in a 74 nova subframe!! Thanks
Old Oct 18, 2016 | 11:11 PM
Bryce0210's Avatar
Default Need help mounting an ls in a 74 nova subframe!! Thanks
I have a 74 nova subframe on my 57 Chevy truck. Yesterday I tried to set the ls motor and 4l60 tranny, and the oil pan bottomed out on the crossmember. I am using the clamshell motor mounts with a dirty dingo conversation kit. Amy help, pictures, or ideas would be greatly appreciated thank you
Old Oct 21, 2016 | 11:53 AM
JoeNova's Avatar
Restricted User
You haven't said which oil pan you have.
Old Oct 22, 2016 | 01:12 AM
Bryce0210's Avatar
Sorry it's the stock oil pan that would have been on the 2003 trucks.
Old Oct 23, 2016 | 02:44 PM
Bryce0210's Avatar
Ok so I did get the motor mounted yesterday. However the oil pan is definitely bottomed out on the crossmember. Does anyone have any suggestions on oil pans.
Old Oct 23, 2016 | 03:30 PM
topless2002SS's Avatar
oil pan for LS into 1st gen Camaro pan?
Old Oct 26, 2016 | 05:36 PM
99SSJarhead's Avatar
You are probably gonna need to swap out the truck oil pan for one from a 4th gen camaro or possibly a corvette batwing might work. Otherwise there are aftermarket solutions specific for your car subframe from companies like brp hotrods.
