Road Racing Road Course | Autocross
Weight distribution
Old Oct 17, 2008 | 02:31 PM
fantastixvoyage's Avatar
Default Weight distribution
Any idea of the distribution for a stock '99 Z28??? Trying to locate scales locally for an exact numbers but figured someone here might know approximate numbers.
I'm looking at swapping motors, kmember, rear end, etc over the winter and wanted to take this time to play with weight. For the motor I'm undecided between an iron or alumimum based engine.
Not sure if I just want to cut weight everywhere and stay aluminum block or if going to a tubular Kmember and iron block would be a better combo...
Old Oct 17, 2008 | 03:18 PM
2FAST4U's Avatar
I was thinking about this to. I have lost a lot of weight but also added some. I must still be heavy as my front still sits low about -1".
I have removed all ac/heat,seats,air bags,kmember,arms upper/lower. In the off season I will drop another 150lb of the front. With pin on hood,cutout fenders,bumper!,ect...
There is a pic in the drag forum of a Z28 with 5" of front fender gap due to weight drop. So know I am lost. I realy need base line numbers before the cuts.
Old Oct 17, 2008 | 03:35 PM
JD_AMG's Avatar
From what I've read 4th gens have 56/44 F/R weight distribution.
Old Oct 17, 2008 | 05:38 PM
mitchntx's Avatar
LT1 4th gens are closer to 57 or 58% front.
Old Oct 19, 2008 | 07:27 AM
subtlez28's Avatar
Like JD said 56/44:
I scaled my 02 Z28, not much lightening, besides hollow sway bars.
Me in it ~170, 3/4 tank of gas=3607 total
LF=1041 LR=815
RF=983 RR=767
Front 2024 (56%) Rear 1583 (44%)
Old Oct 19, 2008 | 08:40 AM
AU N EGL's Avatar
Originally Posted by subtlez28
Like JD said 56/44:
LF=1041 LR=815
RF=983 RR=767
The idea is to "corner balance" your car
LF+RR =
RF+LR =
or as above
1041(LF) + 767 (RR) = 1808
983 (RF) + 815 (LR) = 1798
LF+RR= 1808 = 50%
RF+LR=1798 = 50%
This car with driver is balanced.
Old Oct 19, 2008 | 08:49 AM
mitchntx's Avatar
Not sure where my mind was ...
LS1 equipped cars should be closer to 57%.
I weigh 275 and my 96 TA came off track last weekend with almost a full tank of gas at 3360. So the car weigh under 3K dry.
I'm tall enough that I have the seat mounted to the floor in the rear passenger footwell, probably 8-10" further back that stock.
