Harness advice Needed!!
Brand / Style?
Sponsor to get them from?
How to mount sholder harness?
I do have a cage that I can mount to for the sholder straps, but I am not sure how. I was going to use the original bolt holes for the lap belt portion, but I am unsure about the sholders. Any advice & / or recomendation on what belts to get is appreciated.
I do some dirt track racing and have always used Simpson, but I don't see too much about them in the searches here and I was wondering if there was a reason.
for the shoulder, i had my harness bar made so that i could install eye bolts for the clips. you will either need proper brackets welded on your cage, or just used the wrap around method. perfectly safe, and i think thats whats called the 'porsche' style.
latch & link or camlock is personal pref. latch will be cheaper, but camlock will be easier and faster to lock in. personally, i like saferacer.com for any kind of safety gear. best prices, wide selection.
. Here's a picture of my '93 Z28 race car's seat / belts ... you can see how the strap is simply wrapped around the bar behind the seat, and the lap belts are bolted in at the factory belt locations
The bar should be a few inches below shoulder height and the belts should not exceed a 30* angle from the shoulder down to the bar.
I have trouble using the lap belt mounting points. The factory bolt shoulder is too big to go through the belt tab and I can't find strong enough bolts that have the metric thread and pitch to replace them.
I have begun using grade 8 bolts, typically supplied, and drill out the factory threads and put a nut on the back side. On the outside, I cut a small access panel in the bottom of the rocker panel to get a wrench on the nut. I then seal the hole with a patch panel, silicone and rivets.
Curious if I'm missing a simpler alternative.
I was going to try to keep the stock belts in place mainly for insurance purposes, but the car is just a weekend / track day car to play with, so I don't think I will have much problem with the inconvenience of the harness, but is the cam lock that much more convenient than the typical latch? That is all I have ever had.
NASA CCR.
The shoulder harness shall be mounted behind the driver and above a line drawn
downward from the shoulder point at an angle of no more than twenty (20)
degrees with the horizontal.
Most people around here want their shoulder harnesses level or above their shoulders slightly. If you land on your roof you don't want your shoulder harness holding you down, you want the lap belt to do that. If your shoulder belts where to be bolted to the floor behind your seat then it would probably hurt your back a bit.
-Thanks
