Got some questions
I'll be running in FS for now. I have an extra set of 16x8 camaro wheels. What tires should I get? I was thinking the Kumho tires...but I don't remember which ones were better. I also figure I'll get a 5 pt. harness and a front sway bar to be fairly competitive and save for some shocks. I'll have to take off my lid and STB to run FS, but that's no biggie.
Anything else I should add to my initial list of tires, harnes, and sway bar?
http://www.tirerack.com/tires/Compar...ce=C&x=28&y=13
Tirerack has a lot of good information on competition tires, even offers to heat cycle them for you.
I'm sure Discount offers the same:
http://www.discounttiredirect.com/di...pe=Competition
And they are both sponsors here as well!
If you get the koni's, throw on some good rubber and a big front sway bar. I am currently using the 35mm with the stock rear. It works quite well together.
A friend told me that a shifter knocks me out of stock class, is this true? If so I'm not going to worry about running in one particular class, and just try to gain some experience.
The shifter will knock you out of F-stock (unless there was a rule change that I've not seen yet).
Have fun!
FYI, looking at your sig, there are a bunch of things that technically keep you out of FS. the FRA, ported TB, MAF screen, and shifter all all mods that would bump you to ESP. The car can be competitive there too, and it's up to you if you want to try and run FS like that. I frankly wouldn't care much @ local event, but you might want to mention that to the other guys before they think you're up to something......
As for setting the car up for FS. Easy. 35mm front bar, shocks, wheels and tires.
