Road Racing Road Course | Autocross
Nitto NT555RII
Old Aug 6, 2009 | 09:47 PM
ZexGX's Avatar
Default Nitto NT555RII
Do any of you guys have experience using Nitto NT555RII's? They are supposedly the same compound as the NT555R's but with a stiffer reinforced construction.
Old Aug 7, 2009 | 06:27 AM
EchoMirage's Avatar
personally no, but its tried and true by now. they make a very good street/autox/track tire. i wouldnt hesitate using them as a dedicated or multipurpose tire.
Old Aug 7, 2009 | 11:23 AM
roy's Avatar
roy
I use to run RRII on my Camaro . The tire did pretty well . Grips decent , wears fast ,
Old Aug 7, 2009 | 11:30 AM
ZexGX's Avatar
How would they compare to Toyo Proxy R888 in terms of grip and wear? I do some pretty aggressive driving for street, but nothing as harsh as road racing - so the tires last 100 times longer for me. The drag radial version of the 555's (555R) have been holding up very well under street use.
Old Aug 7, 2009 | 11:35 AM
roy's Avatar
roy
Haven't used the R888 , but have used the RA1. Not much difference between the two.
Old Aug 7, 2009 | 02:41 PM
EchoMirage's Avatar
if all youre doing is street driving, then RIIs will do fine.
Old Aug 8, 2009 | 01:02 PM
ryan breitenbach's Avatar
You might want to try out some Hankooks.
http://www.tirerack.com/tires/tires....el=Ventus+R-S3
The R-S2 is a good tire as well if your looking to save a little.
I haven't had any experience with the Nittos though.
Old Aug 8, 2009 | 01:23 PM
ZexGX's Avatar
The R-S3 and R-S2 both seem to be incorrect sizes for my wheels. The RS-2 doesn't seem aggressive enough for me.
