What cars dominate the SM class?
Here are the results from nationals this past year. Scroll down about 3/4 of the way and you'll find Street Modified.
http://scca.com/popup/raceresult.asp...13555&file=854
Here's a sample of the philly region
http://www.phillyscca.com/solo2/resu...62809.shtml#sm
Philly region breaks SM down a little bit. The FWD cars have their own class (SMFWD)as well as the 2 seaters which have their own class (SM2) so the helps a little bit.
Here's a sample of the North Jersey Region
https://axwaresystems.com/axorm/file...009_fin.htm#sm
I am in the same boat as you. Mods done to my car prior to getting into autox forced me into this class. Its not a class that you'll be competitive in on a national level, but locally you could do just fine. The car just doesn't lend itself to SM very well. It's just too heavy and you can't get it light enough within the rule set of SM. SM is kind of a catch all, in that you could be up against lots of other cars that weren't built for SM, but ended up there as a result of previous mods before getting into autox. But typically you'll be up against BMW M3s, worked Evo's, worked STI's, worked 240SX and all kinds of other stuff. SM usually has decent car counts because of its "catch all" type classing, but the number of those cars actually built for the class can be smallish. C-prepared is another class you could probably run, but again those are usually fully prepped pony cars so you'll likely be out classed and car counts can be super small, you might be the only car in class
I think ESP is about the best place for a modified F-body from a dollar spent/rules envelope/ability to be competitive kinda of ratio, but if you are like me your car is modded too far to turn back now.
Either way have fun.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
If you search around for results you'll find most purpose built F-bodys are in F-stock or ESP. Beyond that they generally end up in C-prepared.
Full on C-prepared F-body....not my car, just an example
http://www.maierracing.com/images/1jesusvillarreal.jpg
I highly recommend taking a good look at the rule book and then make your decision. unlike most forms of racing autocross tell you what you can do as opposed to what you cannot do.
Well you can be in C Prepared and still be street legal I think. In SM you're already at a disadvantage compared to lighter cars, depending on track. On a smaller tighter course little cars will win more, but if you have a big open track the fbodies shine. But you're right, you can be competitive and beat Evo/STI's - with the right setup, and surely the most important part is, practice and driver improvement. If you want suspension parts, look up Strano Parts. He has "the" setup for f bodies. Springs, shocks, swaybars, and 315s.
Frankly, if your Camaro is in SM, you may as well run CP. The fastest SM cars are faster than the fastest CP cars, so the same car will fare better relative to the leaders in CP. CP also has a much better PAX than SM.
Now if you have more local competition in SM than CP, I can understand staying put so you're not racing alone or anything.
