Power steering cooler for auto x?
If just AX'ing for peace of mind I would install a factory one. I've been running a Stock Cooler for almost a year now with no issues, this past summer averaging 101-109 heat.
Road Racing and lapping the car would probably require a decent aftermarket unit.
Dont forget the most important cooler the oil cooler
good luck! Trending Topics
Then I found a place that will revalve your pump for ~$100. Send it to them and they will refurb it and return it to you. Usually takes a couple days. We have a 1/2 dozen of them in our client's race cars, both LS and LT based platforms and no one is complaining.
http://www.pscmotorsports.com/
The valving, pressure and flow rate is altered a little from TO pump specs. We've found them a little better yet.
I have a small, two pass PS cooler on my car. Probably not needed, though as I have also replaced the stock PS reservoir (remember, I'm running an LT1) with a higher capacity, KRC aluminum oil tank. The tank itself transfers heat better than the plastic and I have about 1/2 quart more capcity which helps as well.
I wonder if PSC can install an AN fitting on the top of an LSx pump so that a remote tank can be used? I've never asked.
Mount it in the lower right of the fan shroud, if you dont have a hole there cut one.
I had seen that in my searches but was hoping I could get one with AN lines rather than rubber hose and clamps
