LG C5 converson question
You are gonna drag around a full size spare tire?
If you are paranoid enough to have to have a spare tire, then keep the stocker and carry around a small jack stand so you can switch tires around in the REMOTE chance you do have a flat, are all alone, cell phone battery is dead and all your friends have shunned you.
I've always carried a full sized spare in all my vehicles as well as a small hydraulic jack in a plastic case along with a nice chrome 4 way lug wrench. To me, a flat tire is a 5-10 minute annoyance. To call a wrecker (flatbed) or a friend can take much, much longer. Plus the wrecker costs $.
A full sized spare also lets you drive much faster than the space saver. If you are on a road trip, that can make all the difference.
Note, with this car, I haven't found a hydraulic jack short enough to fit under my lowered car, so I still use the factory jack. God is it slow. I'm also probably going to use the space saver spare for city use and keep a full sized spare at home and carry it only on out of town trips. I also plan on making a nice, durable bag to hold a dirty 315 tire in the back seat area should I need to change it.
I just like being prepared.
All those projectiles you have sitting behind you sounds a lot more threatening as opposed to calling a buddy and waiting 30 minutes ...
Just kidding.
Accident:
1. chance: the way things happen without any planning, apparent cause, or deliberate intent
2. crash: a collision or similar incident involving a moving vehicle, often resulting in injury or death
3. mishap: an unplanned and unfortunate event that results in damage, injury, or upset of some kind
4. chance happening: an event that happens completely by chance, with no planning or deliberate intent
My spare tire would be bolted down or tethered if it was in a position to fly forward.
We are getting way off topic, here.
Jason.
The issue you bring up is a definite concern when one upgrades to larger brakes.
However, the chance of having a flat, while remote, exists.
I guess if GM thought the risk was great, they would have figured out how to get a spare in a C5. But they didn't.
I've seen add on kits, but for the money, I would want one that gives an accurate readout of all four tires so I can keep track of hot and cold temps, etc... The kit's I've seen don't do that.
The LG kit does look good and doesn't require cutting. I guess it's the only alternative now that Bob Bishop isn't making his anymore.
It would also be good if you wanted to fill out a rim or to get some more torque from a stock pad without the increase in brake dust that you get from more aggressive pads. These last 2 reasons aren't that big of a deal unless you think they are worth the 500-600 dollar cost. This is just my opinion. The choice on upgrading your brakes is still up the individual.
Is that a huge difference? I'd hope so for the 2+ thousand dollar price tag.
All i do is autox so i don't actually "need" extra stopping power but i would like some extra stopping power for regular , sometimes slightly agressive, driving.
There is a company in Canada called Williams Performance Friction that have a pad specifically for S2 Autocross. It is extremely grippy cold or hot like a race pad, but has a 750*F limit. Williams says "They have a cold friction rate of 5.5 and a hot friction rate of 5.9 and their service temp is 750 degrees F and after that you will have fade." I take that with a grain of salt, but if those numbers are even close, you better be carefull not to launch yourself through the windshield. They are reformulating it at the moment to increase the heat range a little to respond to some of the higher speed autocross courses that have started to appear. The pad is called the S2. They seem just right for my daily driver as they are supposed to be quiet during daily use and only dust a little. I'm going to get a set in a few weeks (when the new formula is ready) and will report back.
Check this thread for some more info:
http://racing.kos.net/soloforums/sho...s&pagenumber=1
There's probably even more info if you do a search for them on that Canadian forum.
Williams Performance Friction Products are at:
wpfri .com
