A heads up for the guys who track or autoX your car.
My cars never hopped on my NT-05s but once I went up to the big boys and started running A6's and V710's. I nearly **** myself when it first happened. Pad slapping the rear helps also for some reason I hear that LT1 cars tend not to hop like the LS1 cars do. My friend ran his lt1 car no hop. He ran multiple spring rates and is now sitting with 1000lbs penske's in the front.
Auto-x in the heat of summer and fresh A6s= ripped lower control arm mounting bracket right off stock subframe. The factory weld appeared to have been cold with little penetration and lots of corrosion underneath promoting the separation. Good thing it was during a relatively low speed event like Auto-x and it didn't happen during the Time Attack I was running a few weeks earlier while I was using the curbage.
Moral of the story is Auto-x may be taken for granted due to most tracks limiting the speeds to around 60 mph or so but its puts a lot of load on suspension parts almost instantly where road course puts load more gradually.
Agreed. Check all your bolts and ensure everything welded has been done properly. I wouldn't ever put one of those flimsy tubular k members on if you paid me.
More words of wisdom.
-Change your wheel studs immediately to ARP's
-Check your hubs immediately
-Flush your brake fluid to DOT 4 or 5
-Run redline or some aftermarket PS fluid
Also ditch the factory p/s cooler if your car is equipped, all it does is further heat up the fluid. A small transmission cooler plumbed in the return line is far more effective
#34
That is what I am leaning towards. I am sure that your setup is awesome no doubt about it but I am looking at saving money in the long run and it seems that going straight to a Wilwood BBK would be the way to go. I know you recently switched to Wilwood...which one do you recommend? I was looking at the 14 inch slotted rotor 6 piston...
#35
In the end rotor rings are more expensive and you have to change wheel bearings more often with a radial mount caliper. Rotor rings cant be bought at any parts store. Changing rotor rings at the track will suck if you have to.
After my first event with the BBK I did not get a revelation from overhead that the BBK was "the ****". I will know better after 3-4 events.
I see no reason for ARP wheel studs, thats just me though.
#38
Okay. I am assuming along the welds? Or around the mounting holes?
#39
#40
so what I'm hearing is that I shouldn't buy a bmr k member? hmm.. this is news to me... well I'm glad I haven't bought it yet. I wouldn't have figured an aftermarket piece advertised as being stronger than stock would be inferior on the track.
